03-09-2021
15:35
05:14
WilsonFitbit
03-09-2021
15:35
05:14
WilsonFitbit
I've seen many posts about the sense button not working, but usually turning it off and back on seems to fix it. My button would not vibrate or respond to any press. It did still work with the wrist gesture so I was able to power it off. I then had to put it on the charger to get it to turn on. During these couple days, it would also randomly reboot. I talked to fitbit live chat support and the end result was they told me to send it in for repair. They never told me do a factory reset. I tried this as I wanted to wipe my device before sending it in anyways and it seems to have fixed the button issue. It's now working again. Has anyone else experienced this behavior? Also, is there a ticket created or any way to reference a live chat?
Hi @jameska,
Support will usually generate a ticket for you upon request. Unfortunately, there is no way on your end to reference a live chat. However, Fitbit usually has records on their end and should be able to assist you with referencing that live chat.
As far as the button not working, mine only does that when my Sense freezes. A quick shutdown (swipe left to "Settings" and then select "Shutdown") usually solves the issue.
one cruise ship at a time!
03-13-2021
05:19
06:38
03-13-2021
05:19
06:38
Hello @jameska, welcome to the community forums! @DramaQueenDiva, it's great to see you around and thanks for your great input!
@jameska, I'm very sorry for any inconvenience caused and thank you for taking the time to provide your feedback! Please note that our team is always working to enhance your experience with the Sense and your feedback is a big part of that process.
On a side note, I'm glad to know that the Factory reset helped to resolve the inconvenience. The behavior is very odd and I believe that a restart should have worked but that was not the case. Additionally, I was able to see that you have a case with our Support Team. Since you have received assistance from them, I suggest you to either update your case or contact them one more time if you require further assistance. Make sure to mention them that you have a case so our team can locate it and assist you from there.
Have a great day!
