01-24-2023
14:52
14:05
LizzyFitbit
01-24-2023
14:52
14:05
LizzyFitbit
I’m completely new to Fitbit so apologies if this is a dumb question.
I’ve installed the “Photograph” watch face from Fitbit. Is there any way to customise it past choosing which photo I use? I’d like to change the colour / font of the clock, see heart rate or other metrics on the face, etc etc.
thanks in advance.
Best Answer01-24-2023 19:32
01-25-2023 01:26
01-25-2023 01:26
Thanks Guy, seems it’s not possible. I’ll have to see if I can find another third party face that hopefully doesn’t cost too much!
01-25-2023 01:36
01-25-2023 01:36
@RobGy - there are many free ones in the gallery and some apps too, see CardImage app, it may not be exactly what you want but you can get multiple photos, with time, and assign it to long press for easy access and then use a good clock face with a neutral background so it is easier to read and uses less battery.
