10-16-2020
17:46
13:26
LizzyFitbit
10-16-2020
17:46
13:26
LizzyFitbit
I am very interested in buting a Fitbit Sense for the ECG function. I see for the ECG app that there are three possible results that you can receive, Normal sinus rhythym, A-Fib, or Inconclusive. You can then download your results on the phone app and view the actual ecg tracing to show your doctor. Clearly this works for Normal and A-Fib ECG tracings but can you still download and view the ecg tracing even if the result is inconclusive?
I am a medical professional and don't care about the apps interpretation of the tracing, I just want to see the actual tracing. So just because the rate was below 120 or below 50 and the algorithm decides it is inconclusive can I still download and view the tracing myself? Or does the watch not save it as it was inconclusive?
Moderator Edit: Clarified subject and updated label
10-16-2020 19:38 - edited 10-16-2020 19:40
Yes I would think so. Downloading the chart is independent of the algorithm used to interpret the chart.
Best Answer10-17-2020 00:17
10-17-2020 00:17
If you have a heart rate above 100, you will get an inconclusive result. Fitbit advertises up to 120, but this makes me unsure if it can detect Afib from 100 to 120 bpm. I can confirm that you can still download an inconclusive chart.
02-09-2023 23:50
02-09-2023 23:50
Same problem. Also medical and just want to see the “Inconclusive” trace so that I can make my own judgment.
Best Answer02-10-2023 05:05
02-10-2023 05:05
Hello @NickLz and welcome to the Community. Just follow the same steps to download and print your report. My RHR is usually 46-48, and it's hard for me to get my heart rate over 50 sitting still. I tried to add a copy of mine. This site doesn't support pdf files. I know I can convert it and it will show you a Lead I ECG with a heart rate of 48. I don't have that energy right now, so just follow the steps and see your own.
Laurie | Maryland
