10-07-2020
19:43
17:51
LizzyFitbit
10-07-2020
19:43
17:51
LizzyFitbit
I've seen this question in the past about older models, but not yet about the Sense: Is it possible to link both my new Sense (arriving today) and my current Versato my Fitbit account so that I can switch between them, or is it still a case of "only one device per account"?
Best Answer10-07-2020 19:48
10-07-2020 19:48
If it is considered a smart device then no you cannot.
Basically this means you may have 1 newer device and 1 device from blaze/charge 2 or below.
10-07-2020 19:48
10-07-2020 19:48
02-21-2021 09:24
02-21-2021 09:24
that does not help when we have two of the same fitbit, but only one phone. What are we to do?
Best Answer02-21-2021 10:02 - edited 02-21-2021 10:04
Hello @Teacher-321 and welcome to the Help forums. Here's the solution. You can only have one copy of the Fitbit app on your phone. When two users share a phone for syncing, each user sets up an account with their own email account. One user logs out. Then the other user can log in.
Laurie | Maryland
02-22-2021 05:49
02-22-2021 05:49
Best Answer02-22-2021 06:02
02-22-2021 06:02
@Teacher-3212 Accounts work quite well.
However it will be necessary to reconnect Google Assistant each you log back in [if you want to use it].
