08-17-2023
		13:15
		09:14
		08-17-2023
		13:15
		09:14
Can the battery be changed in Fitbit? My current Fitbit works great and instead of getting a new one I’d rather change the battery but don’t know if it’s possible.
08-17-2023 17:30
                              08-17-2023 17:30
Hi @sandee6786 Fitbit doesn't sell parts for these devices. You could probably search online for a company which has a service to replace them or sells the batteries with instructions on how to do it. You would lose any water resistance in having to take the seal off the back when replacing the battery. I'd check first to see how much it would cost and what tools you'd need to do it.
08-17-2023 20:52
                              08-17-2023 20:52
Hi @sandee6786 - agree with @Odyssey13 but why do you want to change the battery if it works great
Often what might seem a battery issue, rarely is, and is more likely something else causing the battery to drain quickly, if that is the issue.
Here's a link to check if that is the case.
How to resolve the Major issues causing short battery life
 Best Answer08-21-2023 05:03
08-21-2023 05:03
The ability to change the battery in a Fitbit device depends on the specific model you have.
08-21-2023 05:11
                              08-21-2023 05:11
Hi @DorothyCarmody - thanks for helping, for info, Fitbit don't repair or change batteries in watches and it is rarely the cause of short battery life. The watch is simply replaced if it is still under warranty.
 Best Answer08-22-2023 09:16
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              08-22-2023 09:16
Hi there, @sandee6786. Thanks for stopping by in the Community Forums. Thanks for the details provided in your post about the issue with your Sense. @Guy_ @DorothyCarmody @Odyssey13 thanks for your comments and input!
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
Was my post helpful? Give it a thumbs up to show your appreciation!  Of course, if this was the answer you were looking for, don't forget to make it the Best Answer! Als...
