02-27-2024
16:46
17:51
AndreaFitbit
02-27-2024
16:46
17:51
AndreaFitbit
Charged my sense last week and now cannot connect to Wi Fi or Bluetooth
Tried reset account, still not working . Now it requires recharging every 24 hours. States the battery charge should last for 6 days? Can not connect to help centre for any satisfaction
Any way I can get support.
Rayb23
Sense is only 14 months old.
Moderator Edit: Clarified subject.
02-28-2024 01:35
02-28-2024 01:35
HI @SunsetRunner - often when you suddenly find a high discharge rate the watch has a fault. But it is not always the case.
If you are still having problems after restarting it and as you are having syncing problems this may contribute to high battery usage.
Let's try to resolve the syncing issue. Logout of the Fitbit App and swipe off the active window and in Android clear the storage cache and force stop it and then restart the phone.
Make sure there are no other devices running the Fitbit App switched on or other watches.
Restart the watch by holding the button for 10 seconds till it vibrates and the logo appears and wait for it to start.
Login and wait for any pair, link or Fixit prompts and sync.
This often resolves the sync and can resolve the battery drain.
If not, remove the watch Bluetooth entries from the phone and in the Fitbit App, setup the watch with Add more devices, select your Sense and replace, then try syncing.
03-14-2024 07:09
03-14-2024 07:09
I tried it with mine, no success... 😩
03-15-2024 08:21
03-15-2024 08:21
Hi there, @SunsetRunner. Welcome to the Fitbit Community Forums. @SunsetRunner Thanks for stopping by! I appreciate you guys for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Fitbit devices are not connecting to your WiFi or Bluetooth. I understand how you must be feeling. We're here to help! @Guy_ Thank you so much for your input!
I've seen you contacted our Support Team after posting here and they've already assisted you. If the steps that our team has provided did not work, please feel free to contact them back for further assistance. Since you already have a ticket open with them it'd be easier to continue the follow up on this matter with them directly. Thanks in advance!
03-15-2024 14:41
03-15-2024 14:41
