02-08-2021 17:10
02-08-2021 17:10
I have a new Sense. I'm connected to a Samsung Galaxy S20. The sense notifies me when I have a new message but the only option I have is to clear or open. When I choose open, it opens it on my phone and not the watch. How do I fix this?
Best Answer02-09-2021 00:42
02-09-2021 00:42
That's how it works, the watch gives you a summary, and a preview if you click on it, but not necessarily the whole message if its long.
Best Answer02-09-2021 05:10
02-09-2021 05:10
02-09-2021 07:01
02-09-2021 07:01
Hi, That's already good feedback.
In which case its probably a setting on your phone that's not exposing the message.
Check the options on your phone for notifications from what ever app that is not making the text available to the Fitbit App.
If the Fitbit App can't see the text it can't send it to the watch.
Best Answer04-12-2021 12:54
04-12-2021 12:54
Any updates to this problem? I have the same problem with my new Sense.
Best Answer04-12-2021 20:26 - edited 04-12-2021 20:29
@JCanPhotoDid you follow the previous advice?
If you have an iPhone see it may help.
Best Answer04-13-2021 07:42
04-13-2021 07:42
Yes, I have tried every setting that I can think of. I have a Samsung S20+.
Best Answer04-13-2021 10:24
04-13-2021 10:24
@JCanPhoto Probably best to contact Fitbit Support directly. They may be able to help you.
Best Answer04-13-2021 15:51
04-13-2021 15:51
Have you made sure that all of your permissions are on allowed for fitbit in your phone?
Best Answer11-16-2021 08:38
11-16-2021 08:38
So, I reached out to tech support and this is what they told me and it worked:
Then, sync your Sense and test the notifications.
On my S20 5G I found it under Notifications > In App Notifications Settings
I was turned off on my phone. I turned it on, sync'd the fitbit, had my husband send me a text and voila! I could read and reply to it!
01-05-2022 10:02
01-05-2022 10:02
I am having the same problem, i get alert that I have a txt msg, only options are open which opens it on my phone, or clear it. I have tried everything above, still nothing has worked, In regards to the notifications settings only options are already checked, i go to in app notification settings options arepreview new messages, but that will show my txt messages on my lock screen on my phone, which i dont want. so now what
