08-28-2023
16:53
07:44
08-28-2023
16:53
07:44
I just got a Fitbit Sense and noticed I'm seeing messages from Messenger, regular texts, but not Signal, it only allows me to view the message itself on my phone. Can this be changed
Best Answer08-28-2023 20:38
08-28-2023 20:38
Hi @Trishb8 - the Fitbit App will send any notifications that appear on the phone's status bar to the watch if setup properly.
In the Fitbit App click profile photo and device photo and Notifications and inside, App notifications and select any apps you want notifications from (providing the app is generating them, they may also need to be configured).
The watch must be syncing and near the phone to receive the notification.
Best Answer08-29-2023 07:50
08-29-2023 07:50
Hi there, @Trishb8. Welcome to the Fitbit Communtiy Forums. Thanks for the details provided in your post about the inconvenience with your Sense. @Guy_ Thanks for your help!
Since you're setting up notifications, you'll need to receive a message from the app desired in order for your app to show it as option in your Fitbit notification section. For example, tell someone to send a Signal message, then check your Fitbit app and you'll see that Signal is already an option to be selected.
I'd recommend following the steps in the article: How do I get notifications from my phone on my Fitbit device?
