11-15-2020 11:43
11-15-2020 11:43
Drove 300 miles from home last week, and weather is still on that city. Tried everything to get it to sync to my city but it will not sync. Changed settings from allow while using the App to always. Rebooted it, still will not sync.
Best Answer11-16-2020 05:13
11-16-2020 05:13
Hi @rb66102 - a suggestion. In the app, select your profile (top left), select Sense (under devices), tap on the apps tile and scroll to the weather app. At the right tap on the settings icon. There it will show a list of cities. Check that "Current Location" is there.
Another thing that may impact - do you have 'automatic location' turned on or off? In the app, select your profile (top left), advanced settings.
It is also important that your smart phone has a GPS signal.
The manual states the following: If the weather for your current location doesn't appear, check that you turned on location services for the Fitbit app. If you change locations or don't see updated data for your current location, sync your watch to see your new location and latest data in the Weather app or widget.
Best Answer11-16-2020 10:55
11-16-2020 10:55
I have two locations set on my Versa. One is for current location and the other set to my home city.
