Can you sync the Sense to an Android phone and iPad?
Or do you have to chose just one device to sync it to?
if you can sync to both, how does the ‘Find My Phone’ app work as which device would it know to send the high pitch signal to?
Thanks.
3 REPLIES 3
You can sync them both.  However, I could not have the app open on both devices within proximity of one another and sync. I had to close the app on one or another. I kept getting a “could not sync” message. There is some sort of conflict. At least that was my experience. Maybe there is a work around but I didn’t explore it further.
Sense Activation 11/3/20\IPhone 12 Pro Max\SimpleClockPro Watch Face\Spigen Rugged Armor Pro Case/Band
Many thanks, Clove6060, good to know I can sync to both/either.
Any idea how the ‘ Find my Phone’ app would work as in - how would it know which device to seek?
Thanks again.
I’m not sure what you mean about “how would it know which device to seek”. The find your phone feature on the sense is when you loose your phone and use the watch to find it. When you loose your phone activate the “find my phone” feature on the sense. Your phone will produce an audible noise so you can locate it. I guess you could try closing your phone down. Run the sense app on your iPad and then try the find your phone on the sense. See if the iPad sounds off.
