02-05-2021 14:46
02-05-2021 14:46
Others seemed to have had this issue with the Sense and indicated to uninstall and then reinstall the app. That fixes the issue for a few days and then I have to do the same. On my 3rd uninstall/reinstall. Is this a known bug in Premium that is going to be fixed? It's not reasonable to continue uninstalling and reinstalling to fix this. I've had my Sense for about a month and am on the most current version of everything.
On Android.
02-05-2021 16:32
02-05-2021 16:32
This has happened to me a couple of time but a phone restart restores the missing data. Also on Android.
02-07-2021 10:29
02-07-2021 10:29
Thanks, will give it a try next time it happens and see if that works vs what I've been doing. Hopefully they'll log as a bug to fix.
