11-27-2021
07:58
05:57
EstuardoFitbit
11-27-2021
07:58
05:57
EstuardoFitbit
On Sense using a android
Open Fitbit app. Click on your picture
Click on picture of your Sense
Click on Gallery
Click on weather (need permission)
Click on setting
Click on unit
When I got here I could see that my Celsius was clicked on even though my app said Fahrenheit.
11-27-2021 08:13
11-27-2021 08:13
I just spent about 30 minutes chatting with tech support - they couldn't resolve the issue. Your solution worked - thank you!
11-27-2021 11:13
11-27-2021 11:13
11-27-2021 11:14
11-27-2021 11:14
Thank you for your feedback. I never could find any thing online so I figured it out myself.
11-27-2021 11:51
11-27-2021 16:59
11-27-2021 16:59
11-27-2021
18:27
12:45
11-27-2021
18:27
12:45
Hi @Beckyspe - that is the way to fix it, but the bigger question is why is it necessary.
Technically, Weather could use the Setting from the App which would be sufficient in 99% of cases, so for the majority the process wouldn't be needed.
This issue has been recognised, we'll have to wait and see if it gets fixed.
11-28-2021 06:27
11-28-2021 06:27
11-28-2021 09:45
11-28-2021 09:45
Thank you! Your instructions work the same way on an iPhone.
01-08-2022 17:14
01-08-2022 17:14
I'm a new fit bit user and have the same problem. I didn't see the solution that was referenced in this thread. Can you please clarify? Thank you.
01-08-2022 17:20
01-08-2022 17:20
Never mind! I found it!
01-14-2022 11:21
01-14-2022 11:21
