10-09-2023 08:50
10-09-2023 08:50
After running the ECG app this morning, parts of my clock face (Dawes) have disappeared. I tried changed to other clock faces, but they also seem corrupted. The Sense was working fine before I ran the ECG. I suspect I need to factory reset, but this isn't the first time display elements have gotten corrupted (e.g. the Alarm app showed times in black so they weren't readable). I suspect a software issue since the display seems to work fine otherwise.
Has anyone else seen this?
Best Answer10-09-2023 10:48 - edited 10-09-2023 10:51
Silver Fitbit Product Experts share support knowledge on the forums and advocate for the betterment of Fitbit products and services. Learn more
Never had that happen on my Sense. But I don't use that clock face, did you try a simple remove that clock face, shutdown, power on, install the clock face? If it happens on other apps, could be the flash is failing, might try a factory reset, but not sure if that would fix a failed flash chip. It would reinstall the software OS. Not sure if that helped or not. Could also be other hardware issues, like screen issues.
10-09-2023 12:01
10-09-2023 12:01
It's happening on more than one clock face. I suspect a memory issue with the software that is causing data to become corrupted. One thing I noticed is that the 5-face limit on clocks loaded on the Sense has been relaxed, since I now have more than 5 faces loaded as a result of my testing today.
