Hi
Does anyone know of a clock face (for Sense) that shows active minutes (NOT active zone minutes) or that shows fat burn minutes and cardio minutes separately?
Thank you.
Hi @Aloraliz - you could try the free SimpleClockPro clock face from the Gallery which shows both AZM and Active minutes (on the second screen) top right corner.
@Aloraliz I don't think you'll have much luck finding an active minute clock face for your Sense, but I could be wrong. The CDC no longer recognizes active minutes as a measure of physical activity. Active zone minutes are consistent with current CDC and WHO recommendations for moderate and vigorous activity. You can always search the Gallery on your mobile app to find clock faces compatible with your Sense. Tap on the devices icon in the upper left > Sense > Gallery. Move the toggle to clocks and use the search feature.
Laurie | Maryland
Best AnswerThanks for the reply.
I doesn't have to be a clock showing active minutes. One that has a separate counter for fat burn minutes and cardio minutes would work too. The information is available in the app and the watch, but it's not convenient to get it. I thought a clock face might solve that problem.
