Hi, @milenagouveiag welcome. To select the default calendar for notifications (I think you need to be running the calendar on your phone) From the today screen in your phone app>touch your icon in the top left>Sense tile>notifications>calendar events> your outlook calender should be there, select it as default. Check the slider on the top right is in the on position, return to the today screen & sync. How do I get notifications from my phone on my Fitbit device? provides additional advice & guidance. I hope this helps.
Cheers
Gr4ndp4 | UK
Best AnswerIt does not work for me, i dont see outlook on the list
Best AnswerHi, @milenagouveiag, do you have outlook installed on your phone? if not I think you will need to install it.
Cheers
Gr4ndp4 | UK
Best AnswerHi, @milenagouveiag FYG I've just added outlook to my Android phone & the calendar is now in the options.
Let me know how you get on.
Cheers
Gr4ndp4 | UK
