03-20-2022 02:01
03-20-2022 02:01
So i m constantly getting message on my fit it app on phone to restart for call and next notification this is really annoying.
Have I just paid 200 for a watch that really isn't all it states it is .
I could of stuck with my charge 3 which I've never had trouble with
Can someone give me some advice before returning this watch plz
03-20-2022 04:28
03-20-2022 04:28
Hi @Lil.pam.
First it will be useful to establish which mobile OS and phone you are using?
I only have experience in the world of Android, where I know some manufacturers employ strict power saving measures (this can cause issues). From what you are saying, this sounds like the result of such measures.
03-20-2022 06:14
03-20-2022 06:14
Sorry yes I totally forgot to mention this. I'm using android and I turned off my power saving mode and this still seems to be happening .
Thanks for the reply
03-20-2022 06:14
03-22-2022 02:23 - edited 03-22-2022 02:27
Hi @Lil.pam, I thought you were going to say Huawei.
Unfortunately Huawei seem to be one of the most notorious of Android OEMs when it comes to aggressive power management.
You can have a look on this page (don't kill my apps) to see if any of the tips there help or make a difference. The trouble seems to be that some of the power management can't be turned off by the user but is instead controlled at a system level.
03-31-2022 09:46
