04-30-2022 09:36
04-30-2022 09:36
Does different color of Fitbit sense, comes with different color display? Grey sense has more brighter and realistic color of icons and watch face than black sense which have slight darker.
Left side grey sense has more brighter icons than black sense with the same brightness option
The pictures are in here for reference:
https://drive.google.com/drive/folders/1-bjamldcnq5wWy26X45NqZDp4Bs4GLTN?usp=sharing
If it is an abnormalities let me know, thank you.
Best Answer04-30-2022 10:37
04-30-2022 10:37
Hi, @Yihyih88, welcome, I'm not aware of any variation in the displays having been reported before. If you are in sleep mode the display will be less bright.
Cheers
Gr4ndp4 | UK
04-30-2022 17:17 - edited 04-30-2022 17:21
Hi thank you but actually both are not in sleep mode, and initially i thought it is a clone or something which makes the display different.btw thank you for the reply.
04-30-2022
21:37
11:13
04-30-2022
21:37
11:13
@Yihyih88 - it is possible that the automatic light sensor adjustment is working slightly differently on the two watches.
It detects variations in light levels and makes small adjustments to the brightness which can change the intensity and give the impression of colour differences of the display.
Best Answer04-30-2022 23:34
04-30-2022 23:34
I not too sure about it, but what I know is the display is a little more saturated.
Best Answer07-09-2022 00:39 - edited 07-09-2022 00:43
I'm finding the whites more washed out on my replacement. And its not as vibrant?
Probably hard to see in the photo though
