01-24-2021
08:26
08:33
WilsonFitbit
01-24-2021
08:26
08:33
WilsonFitbit
It says it needs an app to connect on phone. Is there another app?
Best Answer01-24-2021 09:12
01-24-2021 09:12
You need to install the Fitbit App from the store on your phone and follow the instructions.
Best Answer01-24-2021 12:54
01-24-2021 12:54
That is correct @Help2020fit your tracker will reject* any attempt you try through the phones Bluetooth. Follow the link @Guy_ provided and use the Add device to connect the tracker to your account.
Once connected the app will ask for permission to pair the tracker and you will be promoted to load the firmware.
* two exemptions. Sense control and music control.
08:32
07:08
01-25-2021
08:32
07:08
Hello @Help2020fit Welcome to the Community Forums! @Guy_ @Rich_Laue It's great to see you here in the Forums and thank you for your input!
I noticed that @Guy_ and @Rich_Laue provided information about your inquiry. In addition, you can get more details about using the Fitbit App on your Android, by visiting the following link: What should I know about using the Fitbit app on my Android phone?
Keep me posted.
