10-14-2021 08:54 - last edited on 10-14-2021 12:22 by LiliyaFitbit
How do I download watchfaces ? I click one one to use and nothing happens...
Best Answer10-14-2021 09:36
10-14-2021 09:36
Hi, your watch needs to be synced, then choose the watch face you want to use, tap on install, or Select if it's already installed.
You can't have more than 5 so you may need to pick a non active clock face and remove it. The active one can't be removed.
You can also switch between installed faces by long pressing the clock face, or swipe left and choose Clocks.
10-14-2021 12:29
10-14-2021 12:29
Welcome to the Fitbit Community, @Manxyfive. It’s good to see you around and thank you for your support, @Guy_.
@Manxyfive Thanks for the details shared in your post. I was able to see that you have already contacted our Support team regarding this. Thank you for your time and efforts. You can confirm the instructions to change a clock face in this help article: How do I change the clock face on my Fitbit device?
Please note that your Fitbit watch must be connected to Wi-Fi for some larger apps and clock faces to install or update. For more information, see How do I connect my Fitbit watch to Wi-Fi?
See you around.
