01-30-2024
06:30
08:28
01-30-2024
06:30
08:28
The ECG app has disappeared from my sense. It happened about three months ago and I was hoping the problem would fix itself. It reappeared on its own for a couple days then was gone again. It is not in the gallery either even when searching for it. I live in the United States and made sure my location is set correctly.
I have tried factory resetting my sense, reinstalling the Fitbit app on my phone, and clearing the data and cache.
I have been unable to find an answer to this problem anywhere.
01-30-2024 08:57
01-30-2024 08:57
This has happened to me also - seems to coincide with the Google makeover of the app. Given that the ECG feature was why I bought it, this is every frustrating. I've also tried re-setting it etc but without success. I've now bought a Kardia ECG - it's much easier to use.
Best Answer01-30-2024 09:32
01-30-2024 09:32
I had the same thing happen, the app had been completely uninstalled. It didn't appear in the main 'By Fitbit' category in the gallery, but when I searched for 'ecg' it did appear and I was able to install it again. Alternatively, if you go to the page of one of the other Fitbit apps, tapping View All in the 'More from developer' section at the bottom brought it up in a list for me
Best Answer01-30-2024 09:46
01-30-2024 09:46
Unfortunately searching and 'more from developer' have not worked for me.
