08-24-2021 20:53 - last edited on 08-25-2021 17:12 by LiliyaFitbit
Can't get the ECG to work on my Sense
Just keeps saying open app and set up
08-25-2021
17:11
10:03
08-25-2021
17:11
10:03
It’s good to see you in the community, @Jlewis19.
Thanks for the details shared in your post. I recommend doing the following: open your Fitbit mobile app, tap on your profile picture, tap on Sense, Apps and check if ECG app needs an update or has the requested permissions. Some apps require certain permissions in order to work properly. For more information, see How do I add apps to my Fitbit device?
You can find information about the Fitbit ECG app in What is the Fitbit ECG app?
Best Answer08-26-2021 18:50
08-26-2021 18:50
Thank you. I tried all that and it still does the same thing.
08-26-2021
19:50
10:03
08-26-2021
19:50
10:03
Thank you for your reply, @Jlewis19.
I appreciate your efforts and the additional details. I recommend trying the following:
If the issue persists, I recommend getting in touch with our Support team so they can look deeper into the issue and help you with this matter. Click here to get connected with them via chat or phone.
03-18-2022 15:55
03-18-2022 15:55
I’m having the same issue and have spoken with the “Live Chat” and they can’t help me! They told me to go to the tab and do the ECG intro… that doesn’t even show up for me! It’s basically like the Charge 5 tells me to go to my phone to complete the setup of the app and my phone thinks that the Charge 5 doesn’t even have the app installed (even though it DOES!)
04-01-2022 13:04
04-01-2022 13:04
I had the same problem, but when I restart the sense and on my smartphone force stop the app fitbit (android) and restart my smartphone, the ECG app on my sense worked and it no longer asks me to open the application on my smartphone, thanks.
Best Answer04-01-2022 23:23
04-01-2022 23:23
Connect your mobile with VPN and select locations USA or Canada. Then go to ECG app it works
04-01-2022 23:25
04-01-2022 23:25
Connect your mobile with VPN and select locations USA or Canada. Then go to ECG app it works . Also you can see the hidden apps too
Best Answer06-21-2023 14:32
06-21-2023 14:32
I restarted my phone, and it seemed to work then.
Best Answer07-03-2023 04:31
07-03-2023 04:31
Same issue. Apparently they don't feel obligated to fix issues after they already have your money because here we are over one year later and they still haven't fixed the problem. Well, they can take their garbage back in that case. This overpriced and unsupported trash is going back to the store for a refund.
07-03-2023 04:41
07-03-2023 04:41
Same. The device tells me to setup on the phone app, the notification it sends on the phone to open the app brings me to a page saying it's already installed and to start it from the fitbit. Back to the fitbit and it tells me to set up on my phone and sends another notice that opens the app. Around and around in circles. Not playing these games where they get there money for GLITCHY products ad dont want to do the work to earn that money and are made aware of issues and over a year later it's obviously not been something they care about fixing. I'll be giving them their trash back and getting my money. Nothing more irritating than cash grabs that don't function properly straight out of the box. Maybe in another ten tears or so they might decide to sell a product that functions as advertised and/or push an update that fixes the sloppy development in a timely manner. Yall reported this in 2022 and over a year later in 2023 I buy one and it's still an issue. Unacceptable.
