09-25-2020
05:33
13:20
LizzyFitbit
09-25-2020
05:33
13:20
LizzyFitbit
how do you guys feel using that new band , i personally don t find it comfortable at all. I have tried the small and large band but that did not sort out the feeling . I wont even talk about the pain you can have just to close your band. Fitbit should get a new designer in .
@fanUk26 wrote:how do you guys feel using that new band , i personally don t find it comfortable at all. I have tried the small and large band but that did not sort out the feeling . I wont even talk about the pain you can have just to close your band. Fitbit should get a new designer in .
Ironically, I thought this was the most comfortable band Fitbit has ever had. It is easy to put on, and so comfortable against the skin that I tend to forget that it is there.
Best AnswerThe band is something that I really like about the Sense
Best Answerhow can it be ? the way it closes is putting more stress on your skin , i can t use the large band has it too long and the small one is just ok as im using it at its maximum, so the end of the band is putting to much stress on the point of contact and thats horrible.
Best AnswerYeah, the point where you need to lock it into a hole can be bothersome but more or less every fitness tracker has it's flaws with bands.
I am generally satisfied because once it's wrapped around it's comfortable and doesn't leave marks.
Best AnswerI like the secure lock and having the tap under is way more comfortable than it flopping all over the place.
I have noticed that when choosing the hole I have to take into consideration of the extra space the band takes up. The band needs to be loser than what I would set on the other models.
In any case Amazon already has third party bands.
Best AnswerAgree. I find it reasonably comfortable, and I expect that the hole where it locks will loosen up a bit over time so shouod be easier to get into, but still nice and secure.
