08-18-2022 14:04
08-18-2022 14:04
Hello,
I have a FitBit Sense which is just about 6 months old. With my use, the battery used to last around 5-7 days, but without any change in my user habits, the battery life has begun declining dramatically.
With a full charge and regular use (worn on wrist with screen off), the battery now only lasts about 6 hours before the device is at 0% and turns itself off. I'm not sure what to do about this?
08-18-2022 16:14
08-18-2022 16:14
I’d contact customer service. See if they can provide a replacement. I can’t think of any reason why the battery only last 6 hours except it is failing.
08-19-2022 20:24
08-19-2022 20:24
Mine is doing the same. I just did the latest update.
08-19-2022 20:30
08-19-2022 20:30
I’ve had the same problem since my Sense updated last weekend.
08-19-2022 20:52
08-19-2022 20:52
Thank you for sharing that you are having a similar issue. Sounds like it could very well be connected to the latest update. (Mine also started doing it around that time.) Does anyone know if this will be fixed soon, or if there's a way to roll back the update?
Best Answer08-19-2022 21:47
08-19-2022 21:47
Hey guys, I'm having almost the same problem, except my heart rate stopped working also and while I was working out! 😞 This watch has been flawless for the 1.5yrs that I've had it. Is this the life expectancy? Funny though after the update this happened! WTFudge?!! DMDJAI
Best Answer08-20-2022 00:52
08-20-2022 00:52
I purchased my Sense September 2020 and it's been working fine for the last 23 months. I updated the firmware two days ago, yesterday it went from 30% to 0% in a couple of hours and now I can't get it to charge at all. Since it's outside of warranty they won't replace or repair it but give me a small discount to buy another device. Seems really sketchy to me.
Best Answer08-20-2022 07:53
08-20-2022 07:53
Best Answer08-20-2022 07:56
08-20-2022 07:56
I’m having the exact same problem! When I sought out help from Twitter support they told me to try turning off most of the features on the watch, which is why I bought the sense in the first place. I tried turning off some of the setting which brought me up to 10 hrs.That wasn’t helpful nor was it a solution. I also purchased one for my mother and she’s having the same problem as well.
Best Answer08-20-2022 08:05
08-20-2022 08:05
Best Answer08-20-2022 08:12
08-20-2022 08:12
yes mine also, Fitbit need to rectify this with an updated patch asap as this smacks of the iPhone issues that lowered the battery life that forced customers to buy a new phone!?
Best Answer08-20-2022 08:37
08-20-2022 08:37
Best Answer10-03-2022 17:35
10-03-2022 17:35
My sense has worked fine for months! I've had it maybe 7-8 with no issues. My app updated today and all of a sudden My sense went from 100%-0 in a few hours. I keep it on manual wakeup and do not use any of the fitness tracking apps. It's a glorified pedometer that I can screen text n emails on. No reason for the battery life to change from 5 days to 3 hours... very disappointed. Guess I should have went with samsung after all.. 😞
Best Answer10-03-2022 18:45
10-03-2022 18:45
