11-09-2023 09:30
11-09-2023 09:30
I was going through the Fitbit app settings and can't find where you can choose which apps to get notifications from. There use to be a list and you could pick which apps you wanted to get notifications from. Facebook,email,Google calendar, text messages,etc. It appears to be gone. Am I missing something or is it gone?
Best Answer11-09-2023 10:12
11-09-2023 10:12
Hi @Stronggo I'm using Android and found the settings. From the Dashboard, click upper left on the icon. From there, click on your device. Scroll down to notifications. If you're using iOS, I'd imagine it might be similar. Let us know how things work out for you.
11-09-2023 10:12
11-09-2023 10:12
11-09-2023 19:35 - edited 11-09-2023 19:37
Found it. Thank you. I knew how to find it before but not after they updated the app.
11-09-2023 22:44
11-09-2023 22:44
@Stronggoit took me forever to find the battery strength. When things change, it just takes a bit longer to find things, but you're all good now!
