01-05-2022 11:27
01-05-2022 11:27
Hi,
the Display of my Fitbit Sense seem to be out of order. I get notifications (through vibrations), i can snyc it with my iphone, it counts steps, but the display remains black. I tried to restart the device, but I dont even get the Fitbit logo.
Is there any other way i can reset the Sense or do I need a replacement?
With best regards,
Felix
Best Answer01-06-2022 01:42
01-06-2022 01:42
Hi, @SunsetRunner, welcome, If your "Sense" is vibrating it would appear to be running. Restarting takes a little longer than you might anticipate.
This video demonstrates How to restart your Fitbit Sense / Versa 3 in under a minute - YouTube
If you are not able to make progress you should talk to "Customer Support" here I recommend you use the chat facility or phone for a prompt response.
I hope this helps.
Cheers
Gr4ndp4 | UK
01-07-2022 03:44
01-07-2022 03:44
Did you end up finding a solution? I have tried to reset my sense using the video link advice, and the screen is still black. It seems to still work with my app, and vibrates. The Fitbit live chat gave an error/redirect page. 😞
Best Answer01-07-2022 05:52
01-07-2022 05:52
07:21
11:54
01-07-2022
07:21
11:54
As the watch is syncing with the App, do try to change the clock face in case it is only a clock face fault.
You can also check to see if it responds to swipe up, down, left or right.
In the Fitbit App, Click profile photo, device photo, Gallery to chose a different clock face.
If it is faulty may be the shop will replace it or you can contact Fitbit Support directly.
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
