01-26-2021
13:03
05:05
JuanJoFitbit
01-26-2021
13:03
05:05
JuanJoFitbit
When I first got my Sense, I could go about a week on a charge, now I need to charge it every other day 🙃
Best Answer01-27-2021 05:04
01-27-2021 05:04
Hi @Cyndi85338, welcome to our Fitbit Community. Regarding the battery drain issue that your Fitbit Sense has experienced, I'd like you to try the tips that are listed in this help article in order to improve the battery life of your Fitbit device.
After this, monitor the battery's behavior and see if the issue gets fixed.
Keep me posted on the outcome.
Best Answer01-27-2021 05:15
01-27-2021 05:15
@Cyndi85338 Hello! Go into the Fitbit app and check the apps that are installed on your Fitbit. If you see “SpO2 Tracker” listed as installed on your Fitbit, then that is the likely culprit. I removed it from mine because of the crazy battery drain.
