10-26-2021
10:53
16:39
AndreaFitbit
10-26-2021
10:53
16:39
AndreaFitbit
a few weeks ago the sense battery started to last less and less. it is currently lasting about 2 days tops.
This is used with Android samsung galaxy s21ultra 5g.
Moderator edit: format.
Best Answer10-26-2021 18:01
10-26-2021 18:01
@NiffinMudd or @NiffinMuddintoe I expect it is definitely the snore detection. I think that is most useful for people who don't have any idea whether or not they snore, or how much. I suggest using it for a couple of nights to get a baseline; then turn it off and try again briefly in a few weeks or when you have made changes that you think might affect your snoring amount.
10-26-2021 11:07
10-26-2021 11:07
If you have snore detection turned on, that is a big battery user, best used just a day or 2 at a time.
10-26-2021 16:43
10-26-2021 16:43
Welcome to the Fitbit Community, @NiffinMudd. Thank you for letting us know that your Sense battery is lasting less and less.
Let us know if you use snore detection and confirm that you have followed the steps of help article: Can I extend my Fitbit device's battery life?
Thank you for your help @JohnnyRow.
Keep on visiting the forums.
Best Answer10-26-2021 16:52
10-26-2021 16:52
i do have it set to short time out. I do not use notifications. I do have SPO2 and Snore turned on. but i could turn that off. Just got Cpap. my snore was near 90 dB and alot of apnea. And yes. the snore app was around the time i noticed i dropped to 2 days battery life.
Best Answer10-26-2021 16:58
10-26-2021 16:58
Thanks for getting back to us and for the clarification @NiffinMuddintoe. You can try turning the snore feature off but if it's useful for you, I would recommend charging your watch as needed.
10-26-2021 18:01
12-14-2021 04:22
12-14-2021 04:22
My sense is less than a week old and I have had to charge it every morning from day 1.
I'm ready to return it. The paper that was with it said it had a 6 or 8 day battery life.
12-14-2021 08:11
12-14-2021 08:11
Welcome to the Fitbit Community, @Mcateehardy. Thank you for letting us know that you have to charge your Sense every morning.
I know how frustrating this could be and please check: Can I extend my Fitbit device's battery life? help article. Snore detection and display on all day long can drain the battery faster.
Best Answer12-15-2021 05:19
12-15-2021 05:19
Best Answer12-15-2021 09:44
12-15-2021 09:44
Thanks for getting back to us and for letting us know that you´ll return your watch @Mcateehardy.
Try turning display always on OFF and check how long your watch´s battery lasts.
Have a nice day.
Best Answer03-24-2022 12:09
03-24-2022 12:09
My sense battery sucks, it drains so fast, I charge every other day. I am using Samsung galaxy S21 ultra 5G too. any solution?
03-24-2022 14:17
03-24-2022 14:17
@AJKhan Welcome to the Fitbit community.
What are your settings? I can get 4 whole days with these settings:
Brightness dim, screen wake motion and button, always-on display off, snore & noise detection off, SpO2 on.
The biggest battery drainers, especially overnight, are the snore & noise detection and SpO2, but more so the snore & noise. With it on, I lose around 20% over 7 hours of sleep. With that option off, I only lose around 6-8% over 7 hours of sleep. I had it on for over a week and I don't snore and noise is minimal so it wasn't worth the drain. If I turned off SpO2 I would definitely get 5-6 days. I keep that on because it's part of the health metrics.
Also, keep in mind most battery claims for devices are in ideal conditions and are more of a maximum battery life rather than an average.
03-25-2022 07:40
03-25-2022 07:40
