09-24-2021
18:30
03:44
09-24-2021
18:30
03:44
Has anyone had their FitBit Sense only show the icons and no words?
Best Answer09-25-2021 00:34
09-25-2021 00:34
I've seen a couple of posts reporting this some while back. They resolved the problem by restarting the Sense by pressing and holding the button for around 10 seconds until you see the fitbit logo on the screen. Hopefully this will work for you too.
09-25-2021 00:34
09-25-2021 00:34
09-25-2021 08:06
09-25-2021 08:06
Ok, I will try it as you directed, but is it possible for me to get your number, so I can call and ask for more questions if any arises?
Best Answer09-25-2021 08:15
09-25-2021 08:15
No, I'm afraid not. If it doesn't work then post again and hopefully someone will be able to help
09-25-2021 08:35
09-25-2021 08:35
Ok. Thank you
Best Answer09-18-2022 19:09
09-18-2022 19:09
SteveH,
Have you had any luck sorting this out? Mine started doing the exact same thing. Restarting by pressing the button for 10 seconds, checking for updated driver, and restarting from the app all do not work. Help!
Tony
Best Answer09-18-2022 21:27
