04-20-2021 08:43
04-20-2021 08:43
Hello,
when I bought my old Fitbit device, you had a feature-comparison on your webseite, where I could compare two tra ckers.
I want to have such a comparison of the "Fitbit Sense" and the "Fitbit Versa 3".
Wehre do I find it?
Is it also avaliable in German lanuguage?
Best regards
OLLI
04-21-2021 11:18 - edited 04-22-2021 02:42
@OLLI_S Fitbit seems to have taken that option away. This page from Wikipedia has a chart with a lot of information about all the devices. It really doesn't have the differences between the Sense and Versa 3. But the Sense has hardware that the Versa 3 doesn't.
Did you know there is German forum? At the bottom of the page, you can switch from English to German. There are a few Community Council member who are active in the German forum. I'm sure you can get additional help in your native language.
Laurie | Maryland
04-20-2021 09:06
04-20-2021 09:06
Hi @OLLI_S I only have the English version to share with you. Might be there is a German version, but I'm not sure where it's located.
https://www.fitbit.com/global/us/products/find-your-fit
Maybe if you play with the url, you could find it in German.
04-20-2021 13:03 - edited 04-20-2021 13:04
Hello @Odyssey13 ,
thank you for the link, but this is not what I really intended.
When I answer all questions, then Fitbit suggests both: the Fitbit Sense and also the Fitbit Versa 3.
But in the past there was a comparison chart where I saw a list of features (first column) followed by one column for each device.
And each cell there was a checkmark (when the feature is available) or a "-" (when the feature is not available).
Such a comparison helps finding the proper device.
Best regards
OLLI
Laurie | Maryland
04-22-2021 06:08 - edited 04-23-2021 05:53
To add to what @LZeeW I would like to add that Sense has also gyroscope that Versa 3 hasn't. Because of this reasons Sense can track swimming laps in real time, differently than Versa 3.
In addition Sense has a dedicated skin temperature sensor as opposed to a more generic sensor used on Versa 3. Unfortunately Fitbit never explained in detail what this difference really means for the users.
05-03-2021 02:27
05-03-2021 02:27
I bought the Sense now so I have the "largest" model.
