11-11-2021 05:16
11-11-2021 05:16
I've had my sense for 5 days and I've already had to charge it twice and now it's looking like it's only 25% and I charged it 2 days ago. I have an Android phone Samsung Note so I'm not sure what I need to do to fix it. Not happy currently with the battery.
11-11-2021 06:07
11-11-2021 06:07
turn off bluetooth, turn off always sync on and see if the battery behaves after that.
11-11-2021 06:13
11-11-2021 06:13
@looneygirl43 Battery usage rate depends on what apps you have running. My Sense consumes somewhere between 5-10% of battery overnight when I use SpO2. The unit uses up another ~10% if I track a walk with GPS for about 1.5 hours. In my case these are two largest battery hogs.
Also - try restarting your Sense a couple of times in a row and see if that clears up a possible internal routine that might be running an consuming battery life in the background.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
