11-07-2021 10:17
11-07-2021 10:17
I bought Fitbit Sense on 13th August 2021. It now won't charge as one of the 4 pins on the charging cable has recessed so it is not connecting. How do I get a new connector to charge my Fitbit Sense? (I don't use Twitter, nor intend to do so, and when I tried to initiate a support contact it seems like Twitter is the only option). I can't submit a claim for a broken band as that is not my issue.
11-07-2021
10:30
06:02
11-07-2021
10:30
06:02
Hi, seems you have found the cable problem that seems quite common.
Probably best to contact Fitbit Support directly. They should send you a replacement charger under warranty.
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
Also consider buying a replacement cable should the next one go faulty too. Only a few dollars.
11-07-2021 13:28
11-07-2021 13:28
appreciate your quick reply ..... how do I contact Fitbit Support without a twitter account?
11-07-2021 13:33
11-07-2021 13:33
You can chat with online without twitless or call...
