02-05-2021 07:59
02-05-2021 07:59
Hi - my Fitbit Sense is just on a month old and has been working pretty well. This afternoon it randomly turned itself off (black screen) and now doesn't respond to anything. I've tried resetting but when I press the 'button' it doesn't give any feedback at all.
I'm assuming it's a hardware fault and I'll have to return to the store but thought I'd ask just in case anyone has any other ideas.
Thanks in advance
Jules
02-05-2021 11:35
02-05-2021 11:35
Hi, @Hjules , welcome to the community, is it possible your battery charge is too low? I suggest you place it on charge for at least 60 minutes and then retry the restart procedure. You may find video gives you an idea of what to expect.
Cheers
Gr4ndp4 | UK
Best Answer02-05-2021 14:07
02-05-2021 14:07
Best Answer02-06-2021 00:47
02-06-2021 00:47
Hi, @Hjules , on the basis you watched the video and held the side buttons long enough I suggest you talk to "Customer Support" here. I recommend you use the "Chat" facility or the phone.
Good luck
Cheers.
Gr4ndp4 | UK
Best Answer02-06-2021 12:53
02-06-2021 12:53
Have you tried a restart. This is how to turn on the tracker.
Best Answer02-09-2021 00:43
02-09-2021 00:43
Thanks so much for the help. Hardware fault was the final answer and I have a new Fitbit.
02-09-2021 00:43
