03-19-2021
14:54
05:06
WilsonFitbit
03-19-2021
14:54
05:06
WilsonFitbit
My Sense just went off (battery was fine) and now it won't come back on. I have connected it to the charger, but nothing happens....no vibration, nothing on the screen. I've tried all the tips I've read about, but nothing has worked. Help!
Moderator edit: subject/format
Have a look at the suggestion posted here it will help check out the source of the problem.
If it turns out to be a faulty charger or watch probably best to contact Fitbit Support directly. They may be able to help you.
