08-21-2022 19:12
08-21-2022 19:12
Black rubber cement let go and screen pooped off. I used a small amount of super glue (gorilla white) to hold the corners. Seems to be working right now, but....
Purchased on Amazon June 2021.
Can this be fixed? Cost or is this warranty? Honestly the glue fitbit used to seal and close the assembly is really bad.
Best Answer08-21-2022 19:33 - edited 08-21-2022 19:36
Warranty 1 yr or 2 yr depending on your country.
mid under warranty contact Fitbit support.
If no warranty you can see a watchsmith. They may be able to seal. Or you can try the fox Leowood did.
https://community.fitbit.com/t5/Sense/Tips-to-repair-Sense-screen-detached/td-p/4903126
Regardless who fixes it, I would not swim with the watch and be mindful of moisture.
Good Luck
