12-12-2021 13:10
12-12-2021 13:10
Hi I bought my fitbit sense a 2 weeks ago...I have an Android phone...the 1st week the battery was great now I am having to charge my watch every 2nd day...not what I bought the watch for and very frustrating
Best Answer12-12-2021 19:41
12-12-2021 19:41
Hi @Nunontheloose - what settings did you change? Was there a firmware update or Fitbit App update or did you change clock faces or options?
The Fitbit App and clock faces can update automatically.
It you enabled snore detection, readiness report this can affect battery, also music, using GPS etc and SpO2, try removing the SpO2 tracker app and clock face.
See Can I extend my Fitbit device's battery life?
12-13-2021 08:56
12-13-2021 08:56
Same issue. I've had mine for less than a week. Sp02 sensor is off, has to be turned on with button press, set on dim lighting... I charged to 100% last night and when I woke up this morning it was down to 74%. In about 8 hours, I lost over 25%. This is ridiculous. Might return and go back to my versa.
12-13-2021 08:59
12-13-2021 09:36
12-13-2021 09:36
Yeah, that was one of the first things I did.
Best Answer12-13-2021 09:55 - edited 12-13-2021 09:56
@ashergrl - try turning off the phone's Bluetooth for the night and restarting the watch.
Also make you don't have snore detectionor any other special features.
If it continues it may be related to the latest firmware which got installed.
Have a look for others with this same problem in the forum.
Probably you can contact Fitbit Support directly. They may be able to help you.
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
