08-20-2022
02:33
05:46
EstuardoFitbit
08-20-2022
02:33
05:46
EstuardoFitbit
Hello
My fitbit sense is 4 months old and has been performing well until the other day. It was at 85% charged when all of a sudden it just stopped working. It won't charge or turn on. It seems to be completely dead. Please can you help. I am new to community.
08-20-2022 02:36
08-20-2022 02:36
I came on here for the same reason. I have had my fitbit sense for just under a year, I put it on charge and when I put it in my wrist I noticed the screen is frozen, it's completely stopped working. What's going on? I don't know what to do
08-20-2022
05:50
10:02
08-20-2022
05:50
10:02
Hi all, if you recently updated the firmware or got it wet, have you tried to restart it? How do I restart my Fitbit device?
Also check that it is actually charging, often that can be a problem and the battery is flat. See the steps to check in How to check charge cable - Sense/Versa 3 won't charge, won't start or blank screen
If that doesn't resolve it try chat via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
If they confirm it is faulty the quickest way to replace it is no doubt over the counter where you bought it.
08-20-2022 07:53
08-20-2022 07:53
08-20-2022 08:38
08-20-2022 08:38
I held the side button for ten seconds till the fitbit sign came up and then it started working again, needed to sync with my mobile again first.
