07-16-2022 21:08
07-16-2022 21:08
It’s been the 2nd year of my Fitbit sense and it keeps restarting from the past one week. It’s booting is ending with the Fitbit logo and no further processing. Please help me to resolve this.
Best Answer07-17-2022 05:50
07-17-2022 05:50
Hi, @Sharafmusthafa, have you tried "Restarting" your "Sense". Hold the side button for about 20 seconds and release it once the Fitbit logo appears, after about 35 seconds the clock face should display and normal service resumed. Is your "Sense" charged? Sync and check the little battery icon in the top right corner of your "Today" screen in your phone app.
Let us know how you get on by posting here again.
Cheers
Gr4ndp4 | UK
Best Answer07-17-2022 08:46
07-17-2022 08:46
07-17-2022 08:59
07-17-2022 08:59
Hi, @Sharafmusthafa, Allowing your "Sense" is charged I think your best way forward will be to talk to "Customer Support" and use the Chat facility or the phone for a prompt response.
Cheers
Gr4ndp4 | UK
Best Answer07-19-2022 05:23
07-19-2022 05:23
07-19-2022 05:36
07-19-2022 05:36
HI, @Sharafmusthafa, It's a pity you are having this experience. Did you check the state of charge as suggested in my earlier post?
Let us know.
Cheers
Gr4ndp4 | UK
Best Answer07-19-2022 14:49
07-19-2022 14:49
This has been happening to me as well. I also talked to costumer service, the guys were telling me to do things that I told them at the beginning I did everything possible and after like 1 hour they told me that they are sending this to the warranty department. I got the same email telling me that it is out of the warranty period and I have to buy another one. After wearing fitbit for 10 years, and also having the subscription for fitbit premium I am so disappointed, I may even consider another brand instead of a new sense that could get unwearable again
07-19-2022 19:06
07-19-2022 19:06
Turned mine on for first time in months , firmware doesn’t update , convenient that warranty up . Never dropped it or anything , Fkn pathetic
Best Answer07-19-2022 19:08
07-19-2022 19:08
This exact thing just happened to me to a tee. Now I don’t know what to do, get new one so it lasts a year or get an Apple Watch
Best Answer07-20-2022 03:58
07-20-2022 03:58
Hi, @bherk29, welcome, If you have not used your "Sense" for some time the battery may have discharged completely. Why isn't my Fitbit device's battery charging? provides considerable advice & guidance. I note that the "Sense" needs to be on charge for at least 30 minutes. In my experience, it may be as long as an hour before you see signs of life. Patience is a virtue. Pay particular attention to the charge cable pins and clean the back of your device.
If unused for a while you may find the best way forward is to go to the app in your phone app tray, clear the cache and force stop the app. Unless you have newer O/S than Android 10 or iOS14 do not delete the app, these O/S versions are the minimum that now supports the Fitbit app.
Go to your Bluetooth settings and "Forget" the "Sense" & "Sense control" now you should pair your newly charged "Sense" to the app again. You may find this video a convenient reference point.
I hope this helps but if you are still stuck please post here again.
Cheers
Gr4ndp4 | UK
Best Answer07-20-2022 05:22
07-20-2022 05:22
The battery is fine and at 100 percent . I did ething humanly possible , deleted app, hard reset phone and watch . Bluetooth , wifi, it doesn’t update . Warranty has ended so that’s y this happened bottom line
Best Answer07-20-2022 06:13
07-20-2022 06:13
Hi, @bherk29 , allowing you have followed my earlier advice, in particular in the final paragraph I suggest you talk to "Customer Support" using the Chat facility or phone for a prompt response. If you are out of warranty they will say so, even if this is the case I would expect them to offer constructive advice.
Cheers
Gr4ndp4 | UK
Best Answer07-20-2022 06:16
07-20-2022 06:16
Yes this is what happened which I knew because my warranty expired . They offered me 35 percent off, but idk don’t need another thing I can dodgeball into a brick wall . Just stops working lmao convenient
07-21-2022 06:54
07-21-2022 06:54
I will likely get an Apple Watch at least they have better warranty
07-21-2022 06:56
07-21-2022 06:56
I was using it every day when this happened. Battery at 100%. I had done the forget device etc. this is a watch defect
07-21-2022 07:03
07-21-2022 07:03
I had talked to costumer service twice. Their “constructive advice” was that they offer me a 30% discount to buy a new sense. It is a shame that Fitbit does not stand for their long time PREMIUM costumers.
Best Answer07-21-2022 07:11
07-21-2022 07:11
Hi I am afraid you don’t understand that the issue is the sense itself and this is a defect of the sense that needs to be addressed by fitbit replacing these watches at no charge
