06-24-2022 07:42
06-24-2022 07:42
Hi ,
I've recently bought a Fitbit sense and have noticed that it does not record calories correctly - for example when I do a 5k run it says I've burned about 60 calories - when I record the same run using my phone it's between 4-500 calories which is more what I'd expect.
Now here's the weird thing 🙂 - I had a Fitbit versa 3 which was fine and accurate but then started doing the same thing . I factory reset both devices and have followed advice on here - the sense is brand new but has the same issue - have I unwittingly amended some setting or is there something else I should be doing ?
Any help here will be appreciated - I've tried all the resets already without success.
Thanksn
Best Answer06-24-2022 11:15
06-24-2022 11:15
Check your weight.
06-24-2022 11:15
Check your weight.
Best Answer06-26-2022 13:02
06-26-2022 13:02
Cheers for this - there was a typo in the weight which I've corrected and normal service is resumed
Thanks again
