The food budget info on my dashboard does not match the budget on the foods tab itself. My dashboard says I am over budget but my foods tab says I'm under budget when I click on it. Why are these not syncing together? Shouldn't bother information match?
Good to see you participating in the community @ashowers36.
Thank you for sharing the inquiry regarding the dashboard.
I'm not sure if you are still experiencing difficulties with this. If that is the case, please, Clear caches and cookies. If you see that the problem persists, please try with another browser.
Please, try to update your Fitbit app: How do I use the Fitbit app?
Best AnswerFood logging is notoriously glitchy. It has been for years. Random items appear and disappear, totals don’t match regularly. Eventually you’ll find a random food has appeared or disappeared from your log and that’s what makes the difference. It’s annoying to say the least and never been fully fixed along with all the other issues with the food log.
