12-23-2020 08:35
12-23-2020 08:35
I cannot get rid of pin number on my sense after setting it up. It is to much of a nuisance. I have tried what others have posted but it does not work for me
Best Answer12-24-2020 12:54
12-24-2020 12:54
The PIN is for Fitbit Pay. Do you want to get rid of Fitbit Pay completely, or are you trying to use it without needing a PIN?
Best Answer12-24-2020 13:16
12-24-2020 13:16
I assume you are referring to entering the passcode every time you remove then put the watch back on.
You can disable this by:
- In the Fitbit app, tap your profile picture, then the Sense image.
- (scroll downn to the bottom) Tap Device Lock.
Just choose the option for "Enabled for Fitbit Pay only". You will no longer have to enter the passcode after removing the watch.
Best Answer12-25-2020 03:45
12-25-2020 03:45
As @Mont-Sly suggests. Assigning the pin to Fitbit pay only is the easiest method.
If you do not use Fitbit pay and still want to completely remove the pin, a factory reset (too much of a hassle andit adbised) would be needed.
