04-07-2024 10:56
04-07-2024 10:56
Hello all,
Wondering what I need to charge my Fitbit Sense when I go to France. A converter? An adapter?
Thanks in advance for your advice!
Best Answer04-07-2024 13:58
04-07-2024 13:58
@WalkingSlowly just buy a plug adaptor that comes with USB sockets. That will solve your problem. I use universal adaptor when traveling.
Best Answer04-07-2024 12:37
04-07-2024 12:37
Hi @WalkingSlowly - Public USB ports are often available, in all sorts of places and a PC can always be used. But the easiest is to charge from a locally bought [or pre-ordered] USB charger, which may be cheaper than an adapter.
France is 220v and US 110v Also they have 50hz and US 60hz which is another reason to use a charger for the country, though many adapt automatically. It's good to ask and be prepared to avoid surprises.
04-07-2024 13:58
Best Answer04-08-2024 04:36
04-08-2024 04:36
@WalkingSlowly Fitbits are dual voltage. @Triletics is correct. A plug adapter with USB ports is all you need.
Laurie | Maryland
Best Answer04-08-2024 15:49
04-08-2024 15:49
@Triletics @LZeeW @Guy_ Thank you for your help.
@WalkingSlowly , A warm welcome to the Community!
I just jumped in, to add to the previous information.
If you purchase a socket adapter to charge the Sense, just make sure that it is low energy and not for fast charging, and it's CE or UL certified.
