05-14-2023
15:09
16:05
AndreaFitbit
05-14-2023
15:09
16:05
AndreaFitbit
My Fitbit Sense has been working great until today. I charged it, and when I put it back on, it wasn't displaying my heart rate. The green light isn't flashing.
I tried a soft restart (holding button down for 10 seconds). Then I contacted Fitbit through a chat and was walked through a factory reset. Guess what, that didn't work either.
Any ideas?
Best Answer05-14-2023 18:59
05-14-2023 18:59
I am having the same issue! Not only is the green sensor light not working, but it also is not tracking my sleep anymore and my battery won’t last a day anymore.
About a month ago, my Fitbit literally just gave up. It died and I could t get it to even charge anymore. I kept messing with it and finally got it to charge. My battery use to last for at least 2 days before this. I’ve had issues with my Fitbit before and they sent me a new one, but this was a while ago. Every time I want to call and ask how to fix my issue, the help line is conveniently closed for the day. So frustrating 🤦🏻:female_sign:🤦🏻:female_sign:🤦🏻:female_sign:
05-14-2023
19:59
14:50
05-14-2023
19:59
14:50
Hi @peggysmitty , @Cmorrow7 - generally when there is a sudden change like no lights on the back or short battery life, there is a watch fault.
If a factory reset doesn't cure it there is internal damage, possibly from water getting in, which also can cause it to get hot when charging, and if so stop immediately.
If the watch is under warranty, 1 to 2+ years depending on country law it can be replaced.
You can always chat via the Fitbit App, click profile photo, Help & support, Contact Customer support for more clarification.
05-16-2023 01:28
05-16-2023 01:28
Why is there no green light on my Fitbit heart rate?
You can check this on the settings app. To get to the settings app swipe left on your Charge 4 then swipe up to find the various app. Tap to change a setting. If the Heartrate app is set to OFF, tap to turn ON, and the green lights should work again.
Regards,
Will
Best Answer05-16-2023 02:30
05-16-2023 09:26
05-16-2023 09:26
I've admitted defeat... and ordered a Charge 5. Thanks for your help.
05-19-2023 16:32
05-19-2023 16:32
Hi,
I just sent an email to Fitbit support, but it is of course a Friday, so I’m sure I won’t hear from them until next week. I got my replacement Fitbit almost exactly a year ago. I think it’s under warranty still, but not sure since it is a replacement. I also have a sense, so there is no way to turn on or off the green sensor.
@peggysmitty- let me know how you like the charge 5 compared to the sense 😊. Best of luck to everyone getting their device working!
