10-16-2020
05:40
10:37
EstuardoFitbit
10-16-2020
05:40
10:37
EstuardoFitbit
I am thinking about buying a versa3 or sense.
My old charge2 caused rash due to the contact points for the battery charger. Therefore I stopped using it.
Please share experience with the Sense or Versa 3.
Moderator Edit: Clarified subject and updated label
10-16-2020 11:21
10-16-2020 11:21
Hi @Purrie - I’ve not had any discomfort with either my Versa 3 or my Sense. But then I do not have a history of allergies like you. My best suggestion, if you want to take a chance, is to purchase the device from a nearby authorized retailer. Most will allow you to return the device to the store for any reason within a certain number of days. Naturally, you should verify their return policy before making the purchase.
11-06-2020 10:37
11-06-2020 10:37
HI @Purrie - I have started experiencing a rash from the metal backing (terminal) side of the watch. This did not occur for me with Ionic. The issue I am having is similar to what others have posted about regarding Versa 2. I have moved the watch to my right wrist now (from my left) to allow my left to heal. I am starting to see development on my right wrist, though I am taking the watch off periodically through the day now to allow for the wrist to heal.
It seems there may be an issue with the type of metal material used on the backing of Versa, Sense line for certain people.
Best Answer11-12-2020 06:46
11-12-2020 06:46
So I had the Fitbit Sense for a few weeks, and I loved it. But unfortunately I have a metal allergy, and I found that I was having discomfort from the charge points on the back of the Sense. I've reached out to the Feature suggestions on a way to cover the charge ports so that we can still use the Sense, and I believe it would work on the Versa as well.
https://community.fitbit.com/t5/Feature-Suggestions/Charger-Connector-Cover-for-Sense/idc-p/4574370#...
is the link to the suggestion, If you think it's a good idea, please vote for it, so they'll consider making it a reality.
Best Answer11-12-2020 13:31
11-12-2020 13:31
I have worn fitbit products for almost 5 years. I got the Sense about a month ago and have broken out, where the metal watch back is against my skin. Lost a layer of skin and actually had a bit of an open raised wound. Never wore the Sense in the shower and always washed and dried and then had the watch air dry, when I shower. Never had an issue until the Sense.
11-12-2020 16:26
11-12-2020 16:26
Hi everyone. It's good to see you here in the forums and welcome to our new members.
Thanks for taking the time to share your experience while wearing your new Sense and Versa 3. I understand your concern about going through this situation and if you've not done so, I'd recommend to check the tips suggested in our Product care page. If by any chance you continue having a discomfort while wearing your Fitbit device, please get in touch with our Support team or let me know so you can receive further assistance.
See you around.
