01-12-2021 14:00
01-12-2021 14:00
Just started using a Sense two days ago and having a problem with heart rate detail not showing on the Sense or iPhone mobil app. The clock face shows my pulse correctly, but if I tap on the heart symbol under today all of the details appear with “- -“ for ranges and zones. I have verified that I have the latest versions of firmware and software.
Best Answer01-12-2021 18:21
01-12-2021 18:21
Hi, @rayphillips, I haven't tested this with the Sense, so can't confirm, but with some Fitbits it can solve this issue by making sure you set up notifications from your Sense to your iPhone.
Best Answer01-12-2021 21:34
01-12-2021 21:34
I do have notifications set to my iPhone so I don’t think that is the problem.
Best Answer01-13-2021 05:12
01-13-2021 05:12
Hello @rayphillips It's great to see you around! @Julia_G Thanks for the input!
@rayphillips Your help is appreciated! I was told by Support Team that you have contacted them and they have provided assistance. I suggest you to update your case if you require further assistance or if you have any additional questions about the outcome of your case.
Have a great day!
