06-18-2022
23:37
14:28
LizzyFitbit
06-18-2022
23:37
14:28
LizzyFitbit
Good morning. Will there be an update on the type of exercises you can select on a Fitbit? Looking to track my paddle boarding sessions. Thank you 😊
Hi @emmalegg75 - probably not an update but have a look in the forums (SUP) and for apps.
I found this
But it may not be ported to Sense. There may be other solutions.
Best Answer@emmalegg75 Your Sense has a shortcut called Outdoor Workout. It uses GPS and is designed for non-step based activities like kayaking (in Fitbit's description), so I think it is an appropriate choice for SUP. It isn't intuitive because Fitbit used the same icon as the Interval Workout shortcut and Fitbit is aware of this.
The developer in @Guy_'s link won't be making this app available for the Sense/Versa 3 SUP by Patrick Federi
Laurie | Maryland
