01-12-2022
07:55
13:20
AndreaFitbit
01-12-2022
07:55
13:20
AndreaFitbit
How do I change my weather app from centigrade to fahrenheit?
Moderator edit: Updated subject for clarity.
Best Answer01-12-2022 10:35
01-12-2022 10:35
Hi @olsonjm25 - see How to change Temperature - for Weather, Centigrade - Fahrenheit, Sense
01-12-2022 10:35
01-12-2022 10:35
01-12-2022 12:31
01-12-2022 12:31
Open app on phone
click on your picture
click sense
click gallery
click sense at top
scroll to bottom, weather
click settings
click unit
click F or C
click done!
01-12-2022 15:13
01-12-2022 15:13
thank you, Guy. I could never have figured out all those steps to change my phone from centigrade to fahrenheit. I'm so pleased with your responding in such a timely manner. Thank you again.
01-23-2022 21:30
03-25-2022 18:49
03-25-2022 18:49
tteteak, thank you SO MUCH!!! I had it set to F in the Fitbit app and was going crazy. I did not realize I had to go into the weather app within the Fitbit app. Again, thank you!
Best Answer06-24-2022 15:28
06-24-2022 15:28
OK, I tried what you did, and it didn't change to Fahrenheit. Funny thing, it WAS on Fahrenheit before, but changed without any input to Centigrade. Now I am unable to change it back.
Best Answer06-24-2022 18:51
06-25-2022 06:41
06-25-2022 06:41
Yes, I did. I do not know how it got to Centigrade in the first place- I never changed it, but there it was. When I followed the steps, I saw that the setting was already for Fahrenheit, but the display was still Celsius. I'm going to try again, but make the changes back and forth to see what happens.
Best Answer06-25-2022 07:25
06-25-2022 09:35
06-25-2022 09:35
Going back and forth did the trick. Thanks for your help.
06-25-2022 14:38
06-25-2022 14:38
Glad I finally came to this community! Now I know if I have an app issue the fix may be with the app, not the Fitbit Sense.
Thanks!!!
07-07-2022 12:30
07-07-2022 12:30
Thank you for the info on changing Centigrade to Fahrenheit. Question, how did you figure that out or did you get it on the ask community?
Either way it was driving me nuts. thanks
07-07-2022 20:30
07-07-2022 20:30
