04-09-2024 16:48
04-09-2024 16:48
How do I change the default pool length in the “swim” section of Exercise. Default setting is 25m but my pool is only 10m so I need to change it to get accurate meters swam!
Can anyone help ??
Best Answer04-13-2024 04:11
04-13-2024 04:11
@JS3188 You are looking on the mobile app and the auto-recognition feature. You set the pool length on the exercise app on your Sense. You must use the Exercise app on your Fitbit to capture this short pool length. You can't do it with auto-recognition. Sorry about any misunderstanding.
Laurie | Maryland
04-11-2024 09:49
04-11-2024 09:49
@JS3188 After you select the swim shortcut, swipe up on the tiny "^" at the bottom of the screen. Swipe up to the pool length setting and tap on it. Swipe down until you get to 10m, then tap on it to confirm.
Laurie | Maryland
04-13-2024 03:11
04-13-2024 03:11
Thanks Laurie
I’m afraid i could not find the little “^” icon on any of the links going through the settings/activity & wellness/exercise/swimming links which just gave me Auto-recognise - “Swimming Longer Than” option. Nothing else on the page!
Thanks for trying to assist me though, much appreciated.
John
04-13-2024 04:11
Laurie | Maryland
04-13-2024 04:18
04-13-2024 04:18
