12-14-2020 23:40
12-14-2020 23:40
How do I change the default measurements of the tumbler and bottles in the water add screen.
Best Answer12-15-2020 11:36
12-15-2020 11:36
Hi @mathewparet are you asking about changing litters to imperial measurements.
Best Answer12-16-2020 01:40
12-16-2020 01:40
No, I mean the default volume of the glass and bottles.
The glasses I have at home are all 475ml as opposed to the 250ml defined in the FitBit app.
The bottles I have at home are all 725 ml as opposed to the 750 ml defined in the FitBit app.
Is there a way I can change the defaults so that I don't need to keep entering the values in ml each time?
Best Answer12-16-2020 17:57 - edited 12-16-2020 18:16
For entering through the watch, I don't think this is possible. You would have found it, if it was.
