05-09-2022
12:09
11:47
AndreaFitbit
05-09-2022
12:09
11:47
AndreaFitbit
Why will my weather app not go to Fahrenheit and is on Celsius even though I have it set to Fahrenheit. I deleted my sense and added back on the app still Celsius . Any help from would be greatly appreciated
05-09-2022 13:37
05-09-2022 13:37
@Dkissel13 Can you clarify something please? Are you making the change in the Settings on the Weather app? There is a temperature on the Units in the App Settings, but a different Settings in the Weather app. Tap on your profile picture > Sense > Gallery > slide the toggle to Sense > scroll down to Weather > set unit to Fahrenheit.
My Versa 3 changes mine to Celsius whenever I need to restart my watch. Not sure why it does this.
Laurie | Maryland
05-09-2022 13:37
05-09-2022 13:37
Laurie | Maryland
05-09-2022 13:45 - edited 05-09-2022 13:46
Hello @Dkissel13
Open your Fitbit App, then tap your profile picture in the upper right corner, now scroll down and tap Sense Now tap Gallery…Next scroll all the way down the page and tap weather. Next tap settings….now tap unit, place a check mark on the choice you prefer either Fahrenheit or Centigrade. Finally tap done. Tap the word “Today” to return to the main page. Sync your Fitbit device to accept the new change you made.
For weather showing directly on the clock face there may or may not be a clock face setting to change.
If it is still a problem,
if you prefer to watch a quick YouTube Video with visual step-by-step visual instructions look here: https://m.youtube.com/watch?v=VNltgLkqf7c
The video is for Versa 3 but the steps are identical
😃I hope this helps
05-09-2022 14:20
05-09-2022 14:20
Thank you so very much! That fixed it.
05-09-2022 14:28
05-09-2022 14:28
That’s awesome @Dkissel13!! 😃 I hope you have a fantastic week and as always Happy Stepping!
05-11-2022 19:15
05-11-2022 19:15
THANK YOU! I was going crazy trying to figure this out! It worked!
12-19-2022 13:25
12-19-2022 13:25
the You Tube WORKS GREAT !!!!
