09-19-2021
18:15
06:16
09-19-2021
18:15
06:16
What is the best way to clean the back of the Sense? I'm reading rubbing alcohol. Is that ok?
09-19-2021 20:17
09-19-2021 20:17
Hi @deamo5333,
I just use a toothpick and gently scrape around the edges and back of the device.
If you want to clean the band, use water and a GENTLE hand soap to clean it if you have a woven band.
one cruise ship at a time!
Best Answer09-20-2021 05:01
09-20-2021 05:01
Best Answer09-20-2021 05:28 - edited 09-20-2021 05:29
@deamo5333 I disagree with the advice offered by @DramaQueenDiva. Fitbit's Wear and Care link states that you should use a soap free cleaner like Cetaphil to clean bands. There is also a list of things NOT to use to clean the device itself. Fitbit says you can use rubbing alcohol and a toothbrush to clean the charging contacts, then wipe dry. I use a very soft baby toothbrush to clean my contacts.
Laurie | Maryland
09-20-2021 05:37
09-20-2021 05:37
02-02-2022 19:41
02-02-2022 19:41
I did have issues with my Sense not recording sleep scores. Discovered I wasn't cleaning the sensors with rubbing alcohol and soft toothbrush often enough! D'oh!! Now working well.
02-03-2022 17:49 - edited 02-03-2022 17:49
02-04-2022
13:18
11:15
02-04-2022
13:18
11:15
In some cases cleaning has to be done often as the battery charge points are prone to collecting stuff in the holes.
As mentioned by @DramaQueenDiva a wooden or plastic tooth pick may me needed to clean the holes and as @LZeeW says soap is not recommended.
Regular attention probably can avoid all sorts of issues.
02-04-2022 13:42
02-04-2022 13:42
05-20-2022 08:01
05-20-2022 08:01
Use a Q tip
rubbing alcohol
And electric toothbrush
Best Answer11-24-2022 06:44
11-24-2022 06:44
I've done everything and it isn't charging. What is the next step after a proper cleaning doesn't work? I'm hearing impaired and depend on the vibration for communication, alarm clock, everything! This one is barely 6 months old. 😞 Help!!
Best Answer12-01-2022 04:51
12-01-2022 04:51
Check the pins on the charger itself. They should be raised. One (or more) may have gotten pushed in and unable to make contact with the indentions on the back of the wearable device. This happened to my charging cable and Fitbit replaced it. (No idea how the contact got pushed in though)
12-15-2022 18:33
12-15-2022 18:33
I tried all of this. But it is still nit charging. So I just placed an order for another charging cable.
